Home > Maintenance & Modifications > (new member) Head light amber strip removal replacement?
Page 2 of 3 <123>
aljo
if you give me a while i will try and find out where i downloaded the instructions etc , i think they must be on another pc
ordinary paint from halfords etc will do the trick
i found it very easy to do the modification but the correct heat and timing in the oven is critical
Post #178824 Sun Jul 20 2008 2:35pm
aljo
Headlight lens removal
Pre heat oven to 200 , unscrew everything from headlight that can be taken off , remove clips etc from lens cover, place in oven for 3 mins exactly , remove and prise lens slowly with a suitible knife , don’t remove black adhesive as this is to be reused
To replace , fit lens and body back together , place in oven for 3 mins again , remove and firmly push together and replace clips while still hot
Hope this helps
Post #178834 Sun Jul 20 2008 5:39pm
ademergen
awsome doing it as we speak... will post some pix if i can figure out how...
thanx again
Post #179008 Mon Jul 21 2008 4:05pm
ademergen
Here we go... Very Happy
http://ademergen.blogspot.com/
Post #179024 Mon Jul 21 2008 7:09pm
Cool looks good
But your one brave brave man Thumbs Up RRS TDV6 Gone but still around
Post #179026 Mon Jul 21 2008 7:12pm
ademergen
I was absolutely bricking it for the entire 3 minutes... the mrs came in half way and couldnt believe i was cooking a bit of my car... looks good now though... glad i did it... getting everything colour coded on the 29th... gonna look goooood....
Post #179029 Mon Jul 21 2008 7:23pm
Steve in germany
Do you need to adjust the time for a fan assisted oven Laughing don't know if I would be brave enough! Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #179030 Mon Jul 21 2008 7:26pm
ademergen
well mine is a fan assisted oven, and it seemed to be just enough... make sure u keep ur eye on it though and make sure no plastic bits touch the edges of the oven to prevent melting... getting the lense off is a struggle, but if u pop it in for an extra 30 secs it becomes easier... but be gentle when prising the bit apart... good luck!!!! be brave, u will be fine!!!!
Post #179031 Mon Jul 21 2008 7:42pm
flydive
Well I'd like to do it, bit worried about the adaptive part of the lights. '08 RRS TDV8
Post #179035 Mon Jul 21 2008 8:08pm
NickM
Would love to have mine done too - but would rather someone do it for me, so if anyone wants to start a business doing this, add me to their list - looks great - although not sure about the strip in 3 parts, would look better in one strip...like yours Aljo, mine has a black grill and a full colour code, so think it would make all the difference - and even though Jay takes the Censored out of me for doing it, I still think the colour code running board looks good too.... Thumbs Up
Post #179060 Tue Jul 22 2008 7:28am
FAT_RRS
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
Go to accstyle.com and they have a video which is also on youtube which shows a guy taking a Lexus headlamp apart (to install halos..you might as well do that and paint it while you are in there..). I stopped watching as soon as he put it into the oven for 15 minutes. I have heard several different temps and times..
Try that out, you will get the idea..
Whoo
I do wish that some company made new headlights and tail lights for our cars. Do you know how many choices I have for the wife's X5? TONS... None for us, we have to have them modified... That's great if you are like me and sure to burn up the headlight while heating it...[/url]
Post #179161 Tue Jul 22 2008 4:27pm
DDX
R-Tec in St. Albans do a headlight exchange.
They can colour code them and remove the reflector. 2006 '56 RRS TDV6 HSE, Java Black, Alpaca Interior, PTI, Sidesteps, 22" Stormers wrapped in 285/35/22 Toyo Proxes, Java Framed SC Grille, Java/Zambezi Side Vents, Matt Black LR3 Door Handles, Matt Black Lower Tailgate Trim, Colour coded lower body trims, Semi Smoked Taillights, Chrome Mirrors and Fog Light Bezels, Reflex Exhaust Back, Full Pentagon AutoGlass Privacy, Tasmod Sills, Clear Side Repeaters, pics in gallery!
Post #179222 Wed Jul 23 2008 8:34am
aljo
looking good Thumbs Up
Post #179429 Wed Jul 23 2008 4:54pm
FAT_RRS
WOW
Post #179431 Wed Jul 23 2008 5:19pm
NickM
DDX, mate tried their web site, but couldn't find anything - if they do, will call them and order two new lights......It's the final touch to the car I want to achieve, and then I can take things easy - it's the only thing that stops me getting TDV8 - all the time I have spent doing this one up....
Post #179444 Wed Jul 23 2008 7:18pm
Page 2 of 3 <123>
