![]() | Home > Maintenance & Modifications > (new member) Head light amber strip removal replacement? |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
if you give me a while i will try and find out where i downloaded the instructions etc , i think they must be on another pc
Headlight lens removal
ademergen Member Since: 20 Jul 2008 Location: Portsmouth Posts: 41 ![]() ![]() ![]() |
awsome doing it as we speak... will post some pix if i can figure out how...
Here we go... |
Cool looks good
I was absolutely bricking it for the entire 3 minutes... the mrs came in half way and couldnt believe i was cooking a bit of my car... looks good now though... glad i did it... getting everything colour coded on the 29th... gonna look goooood.... |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Do you need to adjust the time for a fan assisted oven |
well mine is a fan assisted oven, and it seemed to be just enough... make sure u keep ur eye on it though and make sure no plastic bits touch the edges of the oven to prevent melting... getting the lense off is a struggle, but if u pop it in for an extra 30 secs it becomes easier... but be gentle when prising the bit apart... good luck!!!! be brave, u will be fine!!!! |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Well I'd like to do it, bit worried about the adaptive part of the lights. '08 RRS TDV8
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 ![]() ![]() ![]() |
Go to accstyle.com and they have a video which is also on youtube which shows a guy taking a Lexus headlamp apart (to install halos..you might as well do that and paint it while you are in there..). I stopped watching as soon as he put it into the oven for 15 minutes. I have heard several different temps and times..
DDX Member Since: 17 Jun 2006 Location: London Posts: 112 ![]() ![]() ![]() |
R-Tec in St. Albans do a headlight exchange.
looking good ![]() ![]() |
WOW |
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
DDX, mate tried their web site, but couldn't find anything - if they do, will call them and order two new lights......It's the final touch to the car I want to achieve, and then I can take things easy - it's the only thing that stops me getting TDV8 - all the time I have spent doing this one up.... |
