![]() | Home > Technical > TRANSMISSION FAULT MESSAGE |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
Transmission fault |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
It may also be a low battery condition, especially if the error messages - you may get more of them if that's the case, such as HDC fault, suspensions inactive, etc. - appear only at startup and then clear themselves. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Battery.......
kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117 ![]() ![]() |
i have exactly the same problem with my tdv8. i have called out lr hinderasnce and was told nothing wrong with battery.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Daily calls to LRA should get a response eventually |
Take it to another dealer? If it's easily reproducible then someone just needs to pay attention to what you say |
I had all my sensors changed out, then I suggested the battery,
A dodgy battery can cause all sorts of apparently unrelated issues... MDPs car was a good example of that |
thanks for nthe comments and advice, i will try another dealer and see if i get any joy there. |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
If you have a rear diff pm me as I may have the answer. TDV6 - gone
