Home > Technical > TRANSMISSION FAULT MESSAGE
marttin
Northern Ireland 2007 Range Rover Sport Supercharged Adriatic Blue
Anybody know what this message could be...? its went on and then I re started the car about 2 hours later and with over half an hour of drivin it didnt come on... then in the morning the Transmission fault message came on again........ Any ideas.....?[b][/b]
Post #174927 Mon Jun 30 2008 5:15pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Transmission fault Question Question Question Question = Go to dealer L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #174928 Mon Jun 30 2008 5:16pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
It may also be a low battery condition, especially if the error messages - you may get more of them if that's the case, such as HDC fault, suspensions inactive, etc. - appear only at startup and then clear themselves.
Post #174936 Mon Jun 30 2008 5:50pm
PauloAmore
Scotland
Battery.......
- Get a new one.
Especially if it happens on a cold morning. The you start it, charge the battery, and all is well, until the next cold day. It's not cold in Ireland though....
Or, there could be a transmission fault.... Big Cry 2022 P440e AB
Post #174937 Mon Jun 30 2008 6:22pm
kljw
Scotland
same problem
i have exactly the same problem with my tdv8. i have called out lr hinderasnce and was told nothing wrong with battery.
car went back to dealer, explained fault to chap who collected it, but the blank expression said it all, needless to say, car came back with the stealer saying nothing wrong with it. i did explain it need to be kept over night as the problem occured in the morning, again, blank exspression!
any suggestions how i can get the stealer to re-think and resolve? other than calling land rover and complaining, again.
Post #175016 Tue Jul 01 2008 12:28pm
MAW
Daily calls to LRA should get a response eventually Confused
Post #175056 Tue Jul 01 2008 9:06pm
Take it to another dealer? If it's easily reproducible then someone just needs to pay attention to what you say Very Happy
Post #175080 Wed Jul 02 2008 7:21am
PauloAmore
Scotland
I had all my sensors changed out, then I suggested the battery,
- Worked a treat.
I suppose you could solve it with a battery conditioner. If you use one overnight, you shouldn't get the fault in the morning. Try Accumate.
Or go to the dealer, run the battery down by switching lights radio etc all on for a while. Then start her up and you should get the same fault. Thumbs Up 2022 P440e AB
Post #175099 Wed Jul 02 2008 8:22am
A dodgy battery can cause all sorts of apparently unrelated issues... MDPs car was a good example of that Very Happy
Post #175100 Wed Jul 02 2008 8:36am
kljw
Scotland
thnaks
thanks for nthe comments and advice, i will try another dealer and see if i get any joy there.
Post #175182 Thu Jul 03 2008 8:10am
Josh
If you have a rear diff pm me as I may have the answer. TDV6 - gone
TDV8 - gone
Post #175445 Sat Jul 05 2008 2:38pm
