Home > Technical > Low Coolant Level
TA TO TATA
United Kingdom 2008 Range Rover Sport TDV6 HSE Alaska White
Low Coolant Level
Just had car returned from dealer for 4th time re. above warning display and no liquid in expansion tank. 1st visit tank and sensor changed, 2nd and 3rd air lock cleared. This time dealer kept car longer and posted LR by e-mail for technical assistance. LR replied "looks like you have an air lock" - think the dealer had worked that out already for himself! Today dealer vacumn filled coolant system which removed more air - fingers crossed.
Really excellent car otherwise but check out my signature if you are thinking of buying one. OWN A D3 AND A RRS.
DISCO RULES - SORRY CHAPS.
Post #173751 Fri Jun 20 2008 8:56pm
JGreg1
United States 2006 Range Rover Sport Supercharged Java Black
I assume you are already aware of the TSB on the low coolant level warning? I was having this problem when I bought my used 2006 RRS, but took it in, mentioned that TSB, and they fixed it with no problems since.
Post #173757 Fri Jun 20 2008 9:44pm
TA TO TATA
Thanks for the quick response but excuse my ignorance as what is the TSB? OWN A D3 AND A RRS.
Post #173758 Fri Jun 20 2008 9:51pm
RRS_bunny
2010 Range Rover Sport Supercharged Santorini Black
Is the TSB on the net somewhere?
Have had my RRS in to the dealers twice now to fix the low coolant message, with no success.
Post #223846 Thu Apr 30 2009 4:02am
MAW
Tech Service Bulletin i think - look in member Bobby's gallery and it will be in there.... Thumbs Up
Post #223853 Thu Apr 30 2009 7:06am
There was a problem with the coolant expansion bottle on early models of the RRS and these needed replacing - I doubt a 2008 model will have this problem as this should have been sorted by now. 2005 Zambezi TDV6 - Gone but not forgotten
Post #223855 Thu Apr 30 2009 7:28am
ViewWise
ive seen low coolant level twice in the year of ownership and had to top it up a small amount each time (checked level visually and it was at the lower line of the fill range). Reckon ive got an issue?. Obviously not a sensor issue since it was right but should the car be loosing any water? WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #223899 Thu Apr 30 2009 10:34am
Shouldn't need to top up too often - you might have a leak.
Post #223902 Thu Apr 30 2009 10:41am
ViewWise
yea havent topped in since like december and before that it was summer. Is that too often? WINNER - 2008 Best All New Photograph
Post #223904 Thu Apr 30 2009 10:47am
Depends how much you put in - less than a pint and you should be fine. 2005 Zambezi TDV6 - Gone but not forgotten
Post #223906 Thu Apr 30 2009 10:55am
ViewWise
yea both times was like half a small evian bottle. WINNER - 2008 Best All New Photograph
Post #223909 Thu Apr 30 2009 11:05am
topping it up with posh water VW Laughing
Next your be washing it with it Whistle
Post #223914 Thu Apr 30 2009 11:35am
ViewWise
Laughing I always put in evian. I once drove further for evian in my last bmw because i though volvic may be too harsh. Laughing
Also on the cleaning comment! I blame you for all the money ive spent on cleaning gear Big Cry Big Cry Very Happy WINNER - 2008 Best All New Photograph
Post #223949 Thu Apr 30 2009 5:15pm
Laughing
Post #223956 Thu Apr 30 2009 6:00pm
