Home > Technical > Low Coolant Level |
JGreg1 Member Since: 04 Jan 2008 Location: Rogers, Arkansas USA Posts: 40 |
I assume you are already aware of the TSB on the low coolant level warning? I was having this problem when I bought my used 2006 RRS, but took it in, mentioned that TSB, and they fixed it with no problems since. |
Fri Jun 20 2008 9:44pm |
TA TO TATA Member Since: 20 Jun 2008 Location: KENT Posts: 2 |
Thanks for the quick response but excuse my ignorance as what is the TSB? OWN A D3 AND A RRS.
Fri Jun 20 2008 9:51pm |
RRS_bunny Member Since: 23 Jun 2008 Location: Australia Posts: 47 |
Is the TSB on the net somewhere?
Thu Apr 30 2009 4:02am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Tech Service Bulletin i think - look in member Bobby's gallery and it will be in there.... |
Thu Apr 30 2009 7:06am |
There was a problem with the coolant expansion bottle on early models of the RRS and these needed replacing - I doubt a 2008 model will have this problem as this should have been sorted by now. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Apr 30 2009 7:28am |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
ive seen low coolant level twice in the year of ownership and had to top it up a small amount each time (checked level visually and it was at the lower line of the fill range). Reckon ive got an issue?. Obviously not a sensor issue since it was right but should the car be loosing any water? WINNER - 2008 Best All New Photograph
Thu Apr 30 2009 10:34am |
Shouldn't need to top up too often - you might have a leak.
Thu Apr 30 2009 10:41am |
yea havent topped in since like december and before that it was summer. Is that too often? WINNER - 2008 Best All New Photograph
Thu Apr 30 2009 10:47am |
Depends how much you put in - less than a pint and you should be fine. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Apr 30 2009 10:55am |
yea both times was like half a small evian bottle. WINNER - 2008 Best All New Photograph
Thu Apr 30 2009 11:05am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
topping it up with posh water VW
Thu Apr 30 2009 11:35am |
I always put in evian. I once drove further for evian in my last bmw because i though volvic may be too harsh. Also on the cleaning comment! I blame you for all the money ive spent on cleaning gear WINNER - 2008 Best All New Photograph WINNER - 2009 Best All New Photograph |
Thu Apr 30 2009 5:15pm |
Thu Apr 30 2009 6:00pm |
