Home > General > Trailer Hitches - Alternatives to OEM?
xLusi0n
The trailer hitches and the kit seems 1) expensive 2) not as versatile.
I'm guessing the trailer hitch receiver I'll have to get OEM, but what about the hitch kit / ball?
Can I use one from this website: http://www.multihitch.com/retail.html
Post #170461 Thu May 22 2008 4:37pm
KenD
England 2007 Range Rover Sport TDV6 SE Zambezi Silver
A problem you may encounter with an adjustable ball hitch is the height of the ball in relation to the rear parking sensors. If it is set too high the sensors will detect the ball. I experience this problem using the OEM adjustable hitch. After complaining RR informed me that I could only use the lowest set of holes even though I needed the next set of holes up. Had to make do with the lower holes as there was no remedy.[/img]
Post #170723 Mon May 26 2008 8:06pm
xLusi0n
Couldn't you just turn the parking sensors off?
Post #170737 Tue May 27 2008 5:47am
modbarra
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
have adjustable t bar fitted to mine, with additional fittings and do not have problem with sensors! think ya might be getting a dealer fob off?
Post #170739 Tue May 27 2008 7:53am
