A problem you may encounter with an adjustable ball hitch is the height of the ball in relation to the rear parking sensors. If it is set too high the sensors will detect the ball. I experience this problem using the OEM adjustable hitch. After complaining RR informed me that I could only use the lowest set of holes even though I needed the next set of holes up. Had to make do with the lower holes as there was no remedy.[/img]
Mon May 26 2008 7:06pm
xLusi0n
Couldn't you just turn the parking sensors off?
Tue May 27 2008 4:47am
modbarra
have adjustable t bar fitted to mine, with additional fittings and do not have problem with sensors! think ya might be getting a dealer fob off?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
