Home > Technical > Minimum Tyre Pressures for Off-Road - Sand Dune |
tastech Member Since: 20 Nov 2007 Location: sydney, australia Posts: 94 |
Jim Where did you end up getting those stauns from? and what was the cost? cheers Steve Toyota Corolla...(((( formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse |
Mon May 19 2008 1:36pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Steve i got them from 4x4 Megastore near Hornsby, i believe any reputable 4x4 shop will sell them. Cost $79 for a set of 4. To be honest 1 or 2 will do it, as i only let 1 tyre down at a time so i could check the tyre pressures and not have to wholesale re-inflate the lot of them. Even managed to get the supercheap auto compressor working again, in the end i did not require the compressor at Stockton, there are service stations within 300 metres at each end of the beach with Air facilities Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Tue May 20 2008 10:53am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
I'm about to order myself some too:
Tue May 20 2008 11:04am |
those be the ones, deflated to approx 18-20 psi on preset, worked a treat Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Tue May 20 2008 11:19am |
