Home > Maintenance & Modifications > What parts needed to fit Brembos |
R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193 |
I tried to fit the Brembo’s I bought at the weekend and I have a problem! I bought callipers off eBay and disc’s/dust shields from Landrover.
Tue Dec 16 2008 4:13pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
No, the correct Brembos fit directly in place of the std caliper brackets using the same bolt holes and bolts. If your Brembos won't bolt up then you have the wrong calipers Cheers
Tue Dec 16 2008 5:40pm |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 |
Do the standard NON brembo hoses fit ok on the new brembo calpers ?
Tue Dec 16 2008 10:03pm |
Use your existing hoses and wear sensor, you'll need the Brembo backplates too. Cheers
Wed Dec 17 2008 9:14am |
Thanks m8,
Wed Dec 17 2008 9:28am |
Diameter is wrong too IIRC, not just the caliper cutout. The plates are not too expensive and easily available from dealers... Cheers
Wed Dec 17 2008 9:55am |
Ahh i see, do you have to split the baring to get the back plate over the hub ? Pete Follow Us On Twitter @bellautos |
Wed Dec 17 2008 9:58am |
