![]() | Home > Technical > Warnings in info screen |
scorpio Member Since: 08 Jul 2005 Location: London Posts: 142 ![]() ![]() ![]() |
tim, i had this message, but after playing around, i found that to raise from acces mode to regular mode i only have to touch switch once, i held it down,to long and car went into off road height |
Scorpio, the RR I ran had a useful repeater switch with the lecky window switches for selecting access height! The Sport makes do without, but then it isn't a mountaineering expendition to get into the Sport even at Normal height! |
Toodeep Member Since: 09 Jul 2005 Posts: 42 ![]() ![]() |
Tim
BN Member Since: 10 Jul 2005 Location: Northamptonshire Posts: 58 ![]() ![]() |
These cars are so electrically intensive and sensitive that a battery voltage minimum of around 12.2 is set. Anything below that will cause all but the starter to either hybanate, go into low power mode or simply not work.
