![]() | Home > Technical > CHECK ENGINE LIGHT!! |
Wow, an honest service manager! |
Maybe you could get this service manager to 'officially' advise you to drive your car to the dealer in San Francisco. This way, in case something untoward happens along the way, LR cannot pin the fault on you. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
225 miles to your office!! what MPG do you get out of yours then?
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 ![]() ![]() ![]() |
I do work from home most of the time, I go into the "city" two to three times each month. As for the mileage, on the way in I go from 7000' to sea level and enjoy 19+ mpg. On the way home it's around 14.5 mpg. I have a print out from the local dealer stating "ok to drive with on..." so, to quote shmoogle, "on his head be it...
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 ![]() ![]() ![]() |
Davis,
noddy and bigears Member Since: 05 Nov 2005 Location: hants Posts: 116 ![]() ![]() |
[. Bad news, he pulled the code(s) PO137 and PO157 which came with the following, "02 sensor bank 1 and bank 2 sensor 2 will need further diagnostic time to verify oxygen senor faults. Cust advised ok to drive" The service manager confided that his technicians need more training to properly diagnose the problem quote] surly the problem has been diagnosed and replacement parts are needed you could find a dealer that uses diagnos autologic its far better than land rovers own |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
I would not be too worried about the Oxygen sensor fault codes. I have had these in previous vehicles and yes, they can prevent your car from performing normally, as the sensors with shut things down to stop you damaging the engine when it 'thinks' it is in peril.
