You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Technical > List of Current LR Technical Service Bulletins for RRS
ivo-1
I paid $12USD for a one day subscription to the LR Global Technical Reference website (http://www.landrovertechinfo.com).
Most of the content is in PDF format. You can get access to:
- Diagnostics (how-to's, OBD hardware training)
- Recalls (only 1 re: parking brake failure)
- Service Actions (only 1 re: engine management software update)
- Service Information (diag. training, wiring diagrams in pdf, workshop repair manual in non-pdf format)
- Technical Bulletins (listed below)
Current RRS Technical Bulletins
20-inch Wheel Installation Limitations.pdf
A-pillar Water Leak.pdf
Air Suspension Connector Water Ingress.pdf
CD Error Message During Loading.pdf
Exterior Paint Defect Reporting.pdf
Front Door Electrical System Malfunctions.pdf
Fuel Filler Flap Latch Repair.pdf
Infotainment System Diagnosis.pdf
KIT Accessory Phone Module Fault.pdf
Lubricant and Fluid Specifications.pdf
Nameplate Paint Deterioration.pdf
Parking Distance System Intermittent Operation.pdf
Rear Brake Noise.pdf
Removal of Transit Wiper Blades at Vehicle Preparation.pdf
Restraint Control Module Fault Code B1A00-49.pdf
Seat Cushion to Backrest Gap.pdf
Steering Gear Noise.pdf
Visibility from Side Mirror.pdf
Sat Jan 07 2006 4:36pm
Josh
That site looks useful paticularly if the dealer needs challenging.TDV6 - gone
TDV8 - gone
Sat Jan 07 2006 5:03pm
Zipperman19
ivo-1
If possible could you please e-mail me the Rear Brake Noise.pdf file? My brakes have had a little squeak for a while now, and i don't know why. My email is zipperman19@gmail(dot)com. If not, i understand.
Thanks,
Zipperman
Sat Jan 07 2006 5:46pm
RRUK
Its more extensivce than that I believe, In fact, I covered this in a thread not so long ago and also downloaded every single document including technicians manuals etc.
If u don't mind sharing I would like to know more info on this "Air Suspension Connector Water Ingress" thanks in advance either way'06 RRS SC BLACK ON BLACK ON BLACK 22' HRE'S
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
