![]() | Home > Maintenance & Modifications > NAv-TV and RSE pack installed |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Hi Just taken the pics but can post them until tonight. I will do it as soon as i get home
Pictures posted.
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
It sure looks like he has the Nav-TV "tuner" hack installed... so he can view a video source.
Yep all included
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Very nice Neil, who did you use to supply/install all this kit? Also did they have many options on the rear screen choice? From your pics I see that you have located the DVD player in the factory provided location in boot.
watteau Member Since: 03 Jan 2006 Location: Dubai Posts: 22 ![]() ![]() |
Neil is that Kevin and Perry Go Large playing on your DVD???? |
Hi
HHhhmmm ![]() ![]() ![]() ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
nickessex Member Since: 21 Dec 2005 Location: Ongar Posts: 39 ![]() ![]() |
hi neilR
Nav-TV does not sell a tuner. If you buy their "TV video input hack", it turns on the dormant TV tuner UI in the system to allow you to select a single video source... but it's not a functional tuner. You can, however, plug in any video source. This could be a TV tuner or anything else. But you'd need to control it via the device itself. |
ok, i understand so the pictures that neilr were showing in his pics were from a dvd player not a tv tuner , but you can only select one source ? so you could not connect a dvd and a seperate tuner ? you could only fit one input.... anyone know any tv tuners with half decent ariels can;t stand the ones with the wires that go round the window frames, they always seem to fall of !
nickessex, Nav-TV also sells a video switcher. |
hi, just a question, there is a post on the disco 3 site that mentions a "woodman" fix to enable another source on the front screen.... anyone heard of this do they have a web site..?? just to compare to the nav tv option.. ?? many thanks, nick |
There is no real "fix"... you can connect any composite video to the rear of the Navigation screen and view it in diag/test mode. (Without RSE, there would be no other way to view the signal... that's when the Nav-TV "tuner" hack comes into play.)
