![]() | Home > Technical > Gearbox problem |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Dealer job mate |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
Thanks Doc
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 ![]() ![]() ![]() |
This may be a silly question, are you in Command shift mode (Sport) as the Auto function only works up to 5th leaving you to manually select 6th, 6th will only be engaged automatically when in full auto mode is selected |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Gary is right but have you not got a transmission fault being reported on the message centre
Thanks lads
That was my next question are you getting Lock-up in 5th
NN
