![]() | Home > Tips & Tricks > Open rear door...courtesy lights come on !!! |
geezo Member Since: 06 Nov 2006 Location: cardiff Posts: 14 ![]() ![]() ![]() |
THIS WAS IN REFERENCE TO SOME OFFERING TO EXPLAIN RE WIRING COURTESY LIGHTS TO COME ON WHEN OPENING REAR DOORS RRS HSE 06
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 ![]() ![]() |
Geezo..the link is here......
HOWS YOUR RRS RRS HSE 06
9 months old now....only done just over 3000 miles in it and it will be due for first service in 3 months time |
had mine since last july, done 18,000 already.... seats are startin to move around a bit and sure i got some road noise in rear end even after i replaced tyres....
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
![]() Brian, can't you come up with something just using a few bits of Velcro? ![]() ![]() |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
gm28 Member Since: 21 Nov 2006 Location: Darlington Posts: 8 ![]() ![]() ![]() |
Sounds good, I'm a bit lazy so this weekends job is to jump a supply off the Load Space lamp (purple wire) into one courtesy lights, doing away with the green/white wire (+supply) and looping a wire through the headlining to the other courtesy lamp. Minimal trim removal this way. I will let u know if it works and post any pics that may help. |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
Watch out for the headlining curtain srs and sensor ! ![]() |
AlanM Member Since: 20 Feb 2007 Location: Victoria BC Posts: 88 ![]() ![]() ![]() |
I looked at this possibilty as it is simple on the right side. But the left side remains to be done, and I personally found it impossible to run a wire overhead behind the roofliner to the left courtesy light. (It might be possible floorwards.) Keep us all updated on your progress, please. I think the best way of all might well be to get a wiring diagram and see how physically close the courtesy light feed comes to the puddle light or cargo space light feed - they may well be in close proximity under the hood/bonnet, near the fuse box, or under the dash. . . . Come for a visit, Victoria is beautiful! |
AlanM, I downloaded all the wiring diagrams to my work PC, will PM you a copy of the interior lighting on monday....see what you think. 06MY RRS 2.7 TDV6 HSE |
rrsport2005 Member Since: 26 Nov 2007 Location: SYDNEY, AUSTRALIA Posts: 8 ![]() ![]() |
Hello Alan,
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
6 months between your reply and the one before! try this: http://rrsport.co.uk/forum/topic5550.html Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Link is dead - anyone have the original documents? 2005 Zambezi TDV6 - Gone but not forgotten
