![]() | Home > Maintenance & Modifications > Supercharged re-map |
Worth speaking to both JE and Turbochip, both of which are forum sponsors. I don't believe SC performance upgrades are done at the ECU like the diesel engines. I believe their route is via upgrades to the charger itself (and exhaust changes). |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 ![]() ![]() |
The Supercharger uses a DENSO ecu which can be re-mapped |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 ![]() ![]() ![]() |
Most upgrades to the Jag 4.2 litre S/C engine have come from a combination of an 'under-drive' pulley as well as an ECU re-flash I think. Gains approximately 50hp. An exhaust upgrade might return an additional 10-20 hp, but I can't verify that.
'Bishman,
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Is the standard ECU so far out there are useful gains without getting any more air into the engine??? Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Simon,
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
any side effects? |
In your response to my post you seem to disparage a pulley exchange, but then two posts below you tell Simon that a pully, (sic), change, exhaust and ECU re-map could get about 80 bhp. So what exactly ARE your thoughts on a pulley exchange; yes or no? Further, pulley exchanges are not a major mechanical problem, normally taking less than 2 hours of labour, plus most, (all?), dealers would have a hell of a time noticing that the supercharger pulley had been switched out. Supercharged engines are not as easy to 'tune' as turbocharged engines are, and the most reliable way to derive a meaningful increase in bhp is to exchange the supercharger pulley, and then re-map the ECU to take advantage of the increased rotational speed of the supercharger. Add to that a freer flowing exhaust, (IF one exists for the RRS S/C), and once might get approximately a 50-70 bhp reliable increase as I originally stated. Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio. |
Bish,
Just a general comment, however in my understanding I dont believe any tuning company (except the big boys such as AMG etc) or expert in this field actually completes full NVH tests for the modified cars - LandRover have to ensure the homologation of the RRS etc and hence I expect edge of the side of caution when it comes to the engine tuning/performance - if they can get more performance and better mpg and still maintain the expected lifetime of the vehicle, then they would do it.
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
good point kaine ![]() ![]() |
Kaine,
good relpy LRtuning ![]() im still undecided as to have mine chipped as yet ![]() ![]() |
yes they do - quite right - so I take it that my comments are part of a disclaimer with a performance upgrade? |
