Home > Technical > PHONE PROB
NCTT
PHONE PROB
hi
has anyone ever come across this prob before pls help ?
have paired my sony erricson 810i to my car but everytime i turn the car back on with bluetooth it asks me for a code.
i.e i have to repeat the process from step 1 again ?
its driving me mad any ideas gratefully received
cheers
Post #85379 Tue Feb 20 2007 1:38pm
NCTT
it comes up new device found everytime
any ideas ?
Post #85380 Tue Feb 20 2007 1:40pm
There should be an option on your phone to automatically accept connection to the car's bluetooth. 2005 Zambezi TDV6 - Gone but not forgotten
Post #85381 Tue Feb 20 2007 1:40pm
NCTT
well to be honest i cant find it, it shud be under my devices but it keeps wiping itself off.
is that where it would be ?
Post #85382 Tue Feb 20 2007 1:47pm
Look in the connections/connectivity/bluetooth settings of your phone. I'm not familiar with this phone but they should be there. 2005 Zambezi TDV6 - Gone but not forgotten
Post #85383 Tue Feb 20 2007 1:53pm
It maybe a software versioning problem. The PTI works best with a particular version of each phone's software.
Follow this link: http://www.landrover.com/gb/en/Vehicles/Ra...ration.htm to the approved phones list and configuration help. The approved phones list is worth downloading (it's a PDF file) as it contains all the supported version info and details any issues that are known.
Post #85384 Tue Feb 20 2007 1:58pm
NCTT
cheers ill take a look
Post #85385 Tue Feb 20 2007 2:03pm
FYI, the supported phone software is:
R1CD001prgCXC1250568_HUTCHINSON_WI
I'm unfamiliar with SE phones, but I expect there is a # code that you can use to display your current version.
Post #85386 Tue Feb 20 2007 2:04pm
NCTT
ive had a look it seems i have a different version that doesnt auto connect everytime, great.
very odd tho as it worked fine on myd3??
Post #85389 Tue Feb 20 2007 2:40pm
Bummer. Likely a different version of the PTI firmware in your RRS. Can you update your phone to right version over the internet or via a Sony service centre or some such?
Post #85391 Tue Feb 20 2007 2:56pm
NCTT
thats is a very good question, and im technically rubbish.
this could take some time ..............
Post #85392 Tue Feb 20 2007 2:59pm
Jimmy_75000
Got a SE phone, once pairing is done, in the bt option, audio device, there is the landrover system. In there, you can select "trust this device". This will allow the "auto connect" without having to input the code every time.
My SE is the M600i, the menu might be different with yours but globaly, you should find your way. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #85410 Tue Feb 20 2007 4:21pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
My SE P910 has a similar menu.
A tip also, for some phones at least, is to change the name from LAND ROVER to something else.
Post #85411 Tue Feb 20 2007 4:28pm
