Home > Maintenance & Modifications > TV on 07 model |
Conceptenigma Member Since: 09 Oct 2006 Location: manchester Posts: 24 |
Hi There, there is no simply bypass on RR Sport 07 model the only way to do this is to fit a can bus interface.
Wed Dec 06 2006 11:57pm |
PeterG Member Since: 31 Jan 2007 Location: Durban Posts: 4 |
Hi Guys
Wed Jan 31 2007 11:49am |
Prestige Audio Member Since: 14 Dec 2005 Location: Rickmansworth, Herts Posts: 31 |
We do a canbus interface which allows the TV to stay on all the time. I will need to double check tomorrow, but from memory, the interface is about £350. |
Wed Jan 31 2007 8:30pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Nav-TV sells a fairly expensive video-in-motion kit, although it is probably cheaper in the UK than it was for me here in the States, since my 2006's playback was disabled even with the car in Park. |
Wed Jan 31 2007 8:59pm |
Hi Guys thanks for the replies, I must say it is frustrating, i wish Landrover would assist but i contacted Landrover South Africa they are not interested, i told them that for me on the navigation it was a step back as at least on my BMW x3 you were allowed to input info in the nav system on the move.
Thu Feb 01 2007 5:59am |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
Peter - it's really helpful if you (and other members) put a brief description of the model and year of your RRS in your signature. As features vary by model and model year - it helps other forum members respond to a query if this information is provided. If you have an 07MY RRS then you should have sat nav on the move. If it is 06 or 05 - you do not. To my knowledge, other than a temporary hack which lasts until the next time the car is started, no one has come up with a workaround for sat nav on the move. I'm waiting for my dealer to advise if the change from MY 06 to 07 is hardware, firmware or software (or a combination) which will determine if it can be retrofitted as a feature for earlier models. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Thu Feb 01 2007 7:08am |
I have put my vehicle description in my signature, My RRS arrived off the ship two weeks ago.
Thu Feb 01 2007 7:41am |
It could be a SA market thing. But are you sure Peter that you have an 2007 model? Your dealer should at least be able to confirm whether or not it is market specific. Advise him that you know in other markets around the globe, it IS available on the move. If it's market specific I guess you are stuffed without going to a third party "fix".
Thu Feb 01 2007 8:55am |
Here in the US satnav entry on the move is still disabled on all 07s (but front RSE viewing while parked is enabled, which wasn't the case last year)... So, I assume South Africa may get the same spec cars as North America, then - or at least the same stupid attorneys. What wood finish do you get with LUX packages over in SA, cherry or walnut? It's cherry here, walnut across the pond...
Thu Feb 01 2007 4:24pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I want cordless headphones as well RRS TDV6 Gone but still around
Thu Feb 01 2007 5:30pm |
Hi
Fri Feb 02 2007 1:49pm |
chex Member Since: 06 Mar 2006 Location: UK Posts: 210 |
thats strange..how come they're not ROW spec |
Fri Feb 02 2007 3:04pm |
sailorman Member Since: 01 Mar 2007 Location: DUBAI Posts: 38 |
hi everybody
Sun Mar 04 2007 12:22pm |
can i program my front screen and switch on the tv function |
Tue Mar 06 2007 9:40pm |
