Home > My Range Rover Sport > Dirty Alloys |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
My Muc Off came from Chain Reaction Cycles in less than 24 hours so I'll give it a try as soon as temperatures rise above freezing.
Fri Jan 26 2007 2:33pm |
ErSa Member Since: 08 Nov 2006 Location: Oslo Posts: 53 |
Try using brake fluid. Just soak a cloth and off the dirt goes. Remember to use rubber gloves as the liquid is agressive not only on dirt but as well on human skin.
Fri Jan 26 2007 7:35pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Brake Fluid? Bit savage, would need a thorough wash down afterwards or there'd surely be no paint and lacquer left? Wouldn't thinners be a safer but equally effective option?? |
Sat Jan 27 2007 5:00am |
Here's a thread from autopia.org - a detailing forum I subscribe to. It discusses the risks and merits of various wheel cleaners...mostly the risks. It seems that products containing hydrogen fluoride (HF) are the most effective...it's just that they may kill you. Same with products containing ammonium bifluoride (ABF). I would suspect much the same caution applies to using brake fluid. There's a health risk to be considered as well as an environmental one. After all...you're going to flush this off down the drain.
Sat Jan 27 2007 6:12am |
More on the brake dust thing...
Sat Jan 27 2007 8:02am |
Is that right Singletrack.., Vaseline on your rear wheels???? Must've driven to the Blue Oyster Bar!!! |
Sun Jan 28 2007 4:56am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Great post Singletrack. Many thanks.
Sun Jan 28 2007 9:34am |
Joking apart, it's actually a really interesting read (thanks ST), especially as alloys really are just about the single most important factor to the overall astehetic appearance of any car. I shall continue using Wonder Wheels, which is reasonably quick and easy to use, highly effective, and never cased me problems. A coat of Diamondbrite afterwards seems to prolong the subsequent treatment intervals, followed by a further coat of autoglym resin polish or Turtle Wax alloy protector when washing the car on a Sunday.., if you've got the time and enthusiasm? |
Sun Jan 28 2007 2:23pm |
The vaseline thing is crazy - as noted in the article, it will just attract dust no matter how well it protects the wheels - cure worse than the disease.
Sun Jan 28 2007 3:49pm |
By the way...do you know how you tell if your wheels are anodized or lacquered? You lick them! Anodized wheels have a metallic taste - lacquered wheels have none. My Stomers betray a hint of terroir, the tannins are still present but you sense the mellowing, with a lovely finish. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Sun Jan 28 2007 3:54pm |
ST said: "By the way...do you know how you tell if your wheels are anodized or lacquered? You lick them! Anodized wheels have a metallic taste - lacquered wheels have none."
Sun Jan 28 2007 5:29pm |
