Home > General > electronic rear dif lock question??
G4LAND
Spain
How does it work the electronic rear dif lock option on the RRS? Does it work completely automatic like the central dif, or you have to lock it, manually? Who has this option on your RRS? Have you used it? Question Idea Question Yuri
(ARS) XE1UN
13 RANGE ROVER SPORT HSE SDV6
Orkney Grey/Black
(Spain)
07 RANGE ROVER SPORT HSE TDV8
JavaBlack/Black
(SOLD)
05 DISCOVERY 3 G4 V8
(Spain)
02 DEFENDER 90 BLACK LE TD5
(SOLD)
13 FREELANDER 2 (LR2) HSE Lux SI4
Havana/Black
(Mexico)
Post #77827 Thu Jan 25 2007 2:01pm
The doc
completely automatic like the central dif Wink
Post #77836 Thu Jan 25 2007 2:11pm
rrsjo
This option is only of use to you IF you are going to do some SERIOUS off-roading. It works automatically in conjunction with the other diffs. It is of no benefit to you on tarmac roads. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #77837 Thu Jan 25 2007 2:14pm
As metioned before it is automatic. On the nav screen you can select 4x4 view and you can see the dif lock icons turning red to green as it works. Only needed for serious offroading! 2005 Zambezi TDV6 - Gone but not forgotten
Post #77843 Thu Jan 25 2007 2:44pm
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
Re: electronic rear dif lock question??
here all about your quastion:
http://www.rrsport.co.uk/forum/post76579.html#76579
Post #77868 Thu Jan 25 2007 4:01pm
G4LAND
Spain
Well, thanks for info; I order mine with Electronic Rear Differential Lock option. I have plans to do some good off road trips. Some desert dunes in Morocco, planning for October Twisted Evil . I will buy a second shoos for my RRS on 17” or 18” for this proposes. Yuri
(ARS) XE1UN
Orkney Grey/Black
(Spain)
JavaBlack/Black
(SOLD)
(Spain)
(SOLD)
Havana/Black
(Mexico)
Post #77994 Thu Jan 25 2007 11:09pm
I think Disco3.co.uk are planing another trip over to Morocco this year again maybe you can meet up with them? Very Happy RRS TDV6 Gone but still around
Post #77995 Thu Jan 25 2007 11:13pm
Depending on what you order you might not be able to fit 17's or 18's on the RRS. 19's with MTRs would do fine. 2005 Zambezi TDV6 - Gone but not forgotten
Post #78000 Fri Jan 26 2007 12:01am
rrsjo
Nothing smaller than 19's will fit a TDV8 HSE, as they are fitted with Brembo brakes as standard. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #78002 Fri Jan 26 2007 12:08am
G4LAND
Spain
THIS IS MY ORDER:Brembo Front Brakes has to fit 19" or 20" isn´t it? Thumbs Up
Range Rover Sport HSE TDV8
Java Black / Black Java Black
Standard Options:
Dynamic Response
Brembo Front Brakes
Extra Options:
Bi Xenon Adaptive headlights
Personal Telephone Integration system
20" 10 Spoke Alloy Wheels (No Cost)
Sunroof
Tyre Monitoring
Rear Dif. Lock Yuri
(ARS) XE1UN
Orkney Grey/Black
(Spain)
JavaBlack/Black
(SOLD)
(Spain)
(SOLD)
Havana/Black
(Mexico)
Post #78005 Fri Jan 26 2007 12:28am
Yep the smallest you can go with Brembo's is 19" RRS TDV6 Gone but still around
Post #78009 Fri Jan 26 2007 12:45am
Which you should be able to pick up cheaply, given the amount of 19s that get chopped in for 20s Very Happy
Post #78050 Fri Jan 26 2007 9:38am
Ebay!! Very Happy RRS TDV6 Gone but still around
Post #78059 Fri Jan 26 2007 10:13am
Post #78067 Fri Jan 26 2007 10:29am
