![]() | Home > General > My car is sick..... |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Dealer called today and said it was air in the system - there thrying to bleed it out and said that the visible fluid was from the first repair and that it will be steamed clean.
UPDATE
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
Probably the pump was the cause of your original high speed suspension collapse. Let's hope this will be the end of the trouble. |
Ditto |
Still not back |
Doc when did she go in and what car are you using now? RRS TDV6 Gone but still around
She went in last Thursday and I have been given a Jag S-type but have been using my mini |
FFRR on its way to replace the Jag! |
Update
noddy Member Since: 19 Sep 2005 Location: Leics, UK Posts: 76 ![]() ![]() ![]() |
Dynamic response? valves? haven't we been here before....????
The Valve "block" maybe a different thingy in the bobby!
Is it Hillendale sorting your car, or is it the dealer who stated the knocking noise was normal? Why the change over Doc? At your request or what? |
The car's in the right place to get sorted anyway Doc. |
