![]() | Home > Maintenance & Modifications > Insect Screens & Turbo Timers |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 ![]() ![]() |
The best insect screens are agricultural ones....if you have a John Deere Tractor dealer near you I'd go there and have a look at the screens they use to protect the radiators/oil coolers....you could probably adapt one of those |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
By turbo timers do you mean some method of maintaining oil pressure as the turbo spins down when you switch off the engine??
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
Thanks Guys
Re :whirring noise on shutdown caused by turbo oiling......mine shuts down abruptly with no extra noise apart from heat "tinkling"
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
This on a TD5 Martin? If so I think you are hearing the centrifugal oil filter spin down, mine takes around 20secs to spin down when warm. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
I have never intentionally let it cool for 10 secs before switching off.
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
As for turbo timers with todays technology on the design of the bearings and the variable rate speed of the impeller etc there is no need for it.
NN
Have you thought about looking at the motorsport products
I'd endorse these comments, providing the engine is allowed some low speed time after a hard run then time at idle doesn't seem critical in my experience - let alone needing to force oil through post-shutdown. My TD5 has 175k MILES (>110k stage 2 tuned) on it on the original turbo, regular oil and filter changes and good quality oil seems to do the trick. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
You have hit the nail right on the head there S
Agreed
