Home > Technical > Highway mode for suspension |
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 |
The MATZKER AND ARDEN BOXES ARE EXACTLLY LOOKING THE SAME!
Sat Dec 02 2006 8:32am |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
You have to wonder. If this highway lowering at 100 mph is programmed into the suspension ECU then surely this can be modified to take effect at a different speed. I don't particularly need the extra 23mm offered by the Matzker/Arden box - but I would like the car to lower itself at say 120 kph and return to normal suspension height at 110.
Fri Dec 08 2006 6:37am |
The module to add video to the screen of the rrs removes the lock for inmotion, so whatexactly you are saying is that, that he now doesnt have the inmotion lock that disables moving the navigation buttons when going faster than a couple of miles? |
Fri Dec 08 2006 8:51am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
When the RRS goes in to low mode dose it show by any lights (the one near the gear box) or anything like that? RRS TDV6 Gone but still around
Fri Dec 08 2006 8:58am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
NO to the above Having tested it one night on an empty bit of dual carriageway I can't say I noticed any difference. Other than it's rock solid at that speed which is good for such a big car. TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Fri Dec 08 2006 9:25am |
Same here Josh i was thinking this the other day and even my mate said the same thing! RRS TDV6 Gone but still around
Fri Dec 08 2006 9:32am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 |
Has anyone tried pressing the Access height button when at speed?
Fri Dec 08 2006 9:38am |
I drive 100mph several times a day, and never feel like my p38 that I could lower it to highway mode, definitely dont feel anything lowering, sorry! |
Fri Dec 08 2006 9:41am |
I did the same driving to Dusseldorf weekend before last - drove several times, for extended periods at over 160 kph (until the wife leaned over and said: "Isn't that a bit fast???!!!" ). Did not notice anything or any display indication of a lowering although I did look for it. I can only assume that it did so. I agree that the car is very stable at speed. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Fri Dec 08 2006 10:15am |
Still a few bits left in Germany....and Montana! 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Fri Dec 08 2006 10:17am |
When I had the FFRR you could see the car lowering at about 65mph, not physically visible but there were flashing LEDs on the ride height adjustment button! I believe that on the facelift 2007 MY FFRR they have removed that feature now. The only drawback of it was that my mother occassionally used to drive the car and if she was a passanger and I was driving a bit enthusiastically she would not hesitate to tell me because she knew what speed the suspension lowered! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Dec 08 2006 11:51am |
No speed limits in Montana? You learn something everyday being on this forum! 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Fri Dec 08 2006 12:31pm |
Indeed you do! On May 29th, 1999 - Montana replaced their non numeric approach to speed enforcement ("reasonable & prudent") to a numeric speed limit of 75 MPH. I correct myself. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Fri Dec 08 2006 12:43pm |
Fri Dec 08 2006 12:44pm |
