![]() | Home > Technical > Why does the ventilation smell??! |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
does it smell of diesel fumes and only when the outside temp is at 5c or below some of my Previous cars
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
It is the smell of the FBH and quite normal TDV6 - gone
jimrrsport Member Since: 18 Nov 2006 Location: Telford Posts: 79 ![]() ![]() ![]() |
No not the fuel burning pre heater, smells even when the fph is not running?
if its not the pre heater then i would get your L/R dealer to investigate some of my Previous cars
Look for the dead pigeon in the engine bay then |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
Could it be a loose exhaust or header coupling? |
Are you sure it smells of exhaust fumes? I used to get the odd whiff of something every now and again through mine, but it was a smell I've smelt out of commercial aircon units too... a slightly ozoney sort of smell, I always supposed it was a byproduct of the conditioning process. |
What did you eat last night?
My FBH was missing |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
I've noticed in the past that if you swith a/c to ECON (i.e. switch off a/c), it smells a little musty. |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
You wouldn't have any of these problems if you just bought a SC instead....
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
You smell |
Called by at the local dealer today who said its just the newness!?! and will burn off in time. so time will tell 2007 TDV6HSE, Java black, 20" 10 spokes, super charger grill and vents, Sunroof, tv, fridge, brembo's plus all the other 2007 bits, Limo Priv glass, turbchipped
