![]() | Home > Technical > 12V socket making to work whe engine off |
odin Member Since: 25 Nov 2006 Location: Krk Posts: 3 ![]() ![]() ![]() |
Have anyone managed to enable the 12V sockets whe engine is turned off? this is very annoying for me, not being able to charge my bluetooth headset overnight in the car. |
I would think that it would be possible to take a feed from an interior light but this would only mean that the power would switch off after 1/2 hour - the on board computer will shut it down. Would like to be wrong though. 2005 Zambezi TDV6 - Gone but not forgotten
Maybe it would be possible to connect it on wire which controls the hazard lights, I can't think of anything else which would be on when the power is off... |
good point. 2005 Zambezi TDV6 - Gone but not forgotten
pulse Member Since: 02 Sep 2006 Location: Dublin Posts: 15 ![]() ![]() ![]() |
You could take a feed off the perm 12v at the back of the radio |
I think that might have a time limit on it. 2005 Zambezi TDV6 - Gone but not forgotten
WOODY179 Member Since: 30 Nov 2005 Location: Derbyshire Posts: 162 ![]() ![]() |
I believe TFC over on the DISCO3 site found where to take a permanent 12v feed from. Take a look at the following picture - should be the same on the RRS.
thank you very much. I hope that I will be able to solve this. |
