![]() | Home > Technical > 275/40/20 or 295/40/20? |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Brian, Have you tried uploading into the gallery - I have never experienced any problems doing this Kaine |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
Brian - uploading photos is a piece of cake! You upload them to your gallery then paste the link from the gallery into your forum post. Uploading pics to the gallery is just a question of selecting to upload photos, browse to their location on your pc and select them. Like MDP, I'd very much like to see a close up photo of your OEM 20" wheels with 295's mounted. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Thanks fellas (Singletrack/Kaine). Yes, I'll get some pix uploaded then asap, including the Rossini front drilled & grooved discs. Watch this space...... |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Wider tyres will result in more tramlining and greater road noise for certain, pus some possible issues with turning circle and steering lock to lock ratio.
