![]() | Home > General > Service Woes |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Oh dear, sorry to hear this.
If there is no fix for the mirrors I would tell your dealer that you want some money! You paid for dipping mirrors and they have a price attached - I bet he gets them fixed under warranty then. 2005 Zambezi TDV6 - Gone but not forgotten
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
interesting post - noticed this recently so turned the function off - its a bit annoying though |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
If I remember correctly, we used to have problems with auto mirror dip function on early model Disco3's and RRS's.
sorry to hijack the thread, however just a bit of extra info for TB - it only happens for memory setting 1 (my setting) - it never happens to my wife who uses memory setting 2 |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
I do get the dipping mirror out of position occasionally (I have set mine up so that only the passenger side mirror dips, not the driver's. I can't figure out why you would want the mirror on the driver side to dip when you back up...) If the mirror does not reposition properly after disengaging reverse, I hit the Memory 1 button on the seat - it is relatively easy to find without looking - and the mirror always goes back in place without touching the mirror adjustment knob. |
How did you programme the one mirror to dip? 2005 Zambezi TDV6 - Gone but not forgotten
for me, pressing the memory 1 button doesn't do anything - I have to press memory 2 and then memory 1 (quickly to avoid getting crushed on the steering wheel |
VA, remember the angle of the mirror you don't want to dip first, I assume it would be the one on the driver side. Then turn the ignition to position II (don't start the car), put the gear selector in reverse and adjust the angle of the driver side mirror back up to where you normally have it - as well as the angle of the other mirror (the one you want to keep dipping in reverse) if you want. Leave the car in reverse and memorize the mirrors position in the seat memory button that you normally use for yourself (Memory 1 in my car.) The display in the instrument cluster should say something like "MIRRORS DIP STORED" and the dip angle will be remembered every time you choose that memory button on your seat, whenever you engage reverse. |
Thanks will try. 2005 Zambezi TDV6 - Gone but not forgotten
Thanks Umbertob |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 ![]() ![]() |
My offside mirror did the same occasionally but pressing Mem button 1 does the trick. Thanks, Umberto ![]() 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Ianf Member Since: 31 Jul 2006 Location: Manchester Posts: 23 ![]() ![]() |
The two things that have surprised me is the number of minor faults theat we all seem to have. And the cost of servicing. other than changing oil and filter what else do they do in the service? Just aqquired a Silver HSE. Also have a TVR Tuscan |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
It works! ![]() ![]() Now...how do I get the mirrors to fold in when I lock the car/activate the alarm? Anyone done this? 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
