Home > Technical > 275/40/20 or 295/40/20? |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
HI DDX - congratulations on the new car! It's just a personal opinion, but I'd go for the 295/40/20 - I have the factory Stomers and they are extremely vulnerable to scrapes and scratches with the low profile tyres. The 295's would give you some extra sidewall and hopefully reduce the risk of damage. I cannot imagine that the replica Stormers are any less vulnerable than the OE ones.
Tue Nov 21 2006 11:07am |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Hmmmm How can the wider 295's give any extra sidewall protection ??? they are both a "40" ratio tyre ?
Tue Nov 21 2006 11:23am |
A tyre's aspect ratio is in relation to width. If the width is greater then this value is relative. The sidewall of a 295mm would be 177mm versus 165mm on a 275mm wide tyre. Based on a 40% aspect ratio.
Tue Nov 21 2006 11:34am |
Your quite correct singletrack ...... this could be the way to go then
Tue Nov 21 2006 11:37am |
Driller Member Since: 18 Aug 2006 Location: Perth Posts: 80 |
Definately go with the 295's. I have them and not only do you have a bit more sidewall, the extra width will help with curbs etc as the tyre has to be squashed more before you can damage the rim. |
Tue Nov 21 2006 11:25pm |
JE Engineering Member Since: 23 Jan 2006 Location: Coventry Posts: 32 |
JE would strongly recommend the 295/40 20 option, and this size is availble from Hankook in RH06 type . Our further recommendation is to fit this to a 10 inch wide rim as it make the side walls more vertical. The normal LR rims are only 9 inch which tends to make the side walls a bit 'tucked in'.
Wed Nov 22 2006 9:40am |
DDX Member Since: 17 Jun 2006 Location: London Posts: 112 |
Thanks alot for all your responses. I think i'm gonna go for the 295 option and probably with conti's. The replica's seem to be 9.5 wide so the side wall won't be perfectly straight but close enough!
Wed Nov 22 2006 11:22am |
Would the difference in the overal tyre ratio affect the final readings on speedometre / trip computer etc etc ?
Wed Nov 22 2006 11:53am |
I was wandering this aswell. As the OEM 20" are -10mm, do Land Rover re-programme the speedo and trip computer for cars with those wheels? I very much doubt it! Check this out: http://www.tyresave.co.uk/tyresize.html It seems that any change which is within +/- 2.5% is pretty insignificant. Once I change wheels I'll hook up my Garmin GPS to check how precise the cars speedo is. |
Wed Nov 22 2006 12:34pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
I've recently upgraded from 275/40 to 295/40 Goodyear F1 Wranglers onto my 20" Supercharged rims without any problems. The extra tread width looks great, the higher tyrewall fills the wheel-arch better, and the ride seems more sure-footed without feeling heavier.
Thu Nov 23 2006 3:04pm |
How about some nice close up pics etc
Fri Nov 24 2006 10:36am |
bigdwarf Member Since: 12 Nov 2005 Location: Luxembourg Posts: 31 |
"[Also, as rolling circumference has increased and the speedo readout reduced, I'm informed the recorded mileage may theoretically diminish by the corresponding percentage (ie 10,000miles would drop to 9,000'ish.., please correct me if I'm wrong).
Fri Nov 24 2006 1:27pm |
Whilst the increased circumference = reduced mileage principle is sound, I share your suspicion that it'll probably be negligible, if anything (more wishful thinking perhaps??). With regard pix, there appears no facility for normal picture uploading onto this website without complications? Shame, because I also wanted to show the recently installed Rossini drilled and grooved discs alongside the 20"wheel+295/40 tyre combination.., nice! |
Sun Nov 26 2006 5:06am |
Ok, I saw a car with 22" Stormer replica's and am now toying with the idea!!
Sun Nov 26 2006 11:37am |
