Home > Technical > NO MORE AUTOMATIC PDC ON RR SPORT, RR&LR3 2007 MODELS
pers1
All 2007 models has disabeled the automatic ON for the PDC (PARKING AID CONTROL)
They have change this after alot of customers complaint that when the speed drops below 16kph(10mph) and I qoute"This can give instances of sensor warnings when the vehicle stops at a junction and another vehicle or pedestrian passes in front of the vehicle, resulting inthe above complaint.This is not a fault with the parking system, however, an alternative system strategy is available so that the system operation is canceled when the vehicle speed is above 10mph (16kph) and will not operate again until the vehicle speed is below 10mph (16kph) and the fascia front parking aid switch is selected (or until a forward gear is selected following reverse gear selection during parking)."
So this is how the "new" PDC works.
1. U must choose R (revers) and then D (drive) the PDC turns itself on, when
been parkered!
2. for the PDC to work without using R (revers) U have to use the fascia front
parking aid switch. youre speed has to be below 16kph(10mph)
When U reach a speed over 16kph(10mph) the PDC will automaticly turn itself off and will stay off even after the cars speed drops below 10mph (16kph).
I U need the PDC U have to either put it in revers or press fascia front
parking aid switch.
I asked som Norwegian LR delears if they knew about the "new" PDC feature and they didn`t they assumed it was working the old automatic way!
July 19 LR`S GTR site posted this for customers that complained about sensor warnings when the vehicle stops at a junction and another vehicle or pedestrian passes in front of the vehicle.
OFFICAL NOTE:
Technical Service Bulletin No.LS413-002
19 July 2006
Subject/Concern: Range Rover Sport - Front Parking Aid False Warnings
Models:
Range Rover Sport
(LS)
Vehicles with front parking aids
Vehicles with front parking aids VIN-range:5A900109-6A960177
Markets: All
Section: 413-13
Summary:
A customer may report a concern that the front parking aid system sounds unnecessarily.
Cause: The current system strategy means that the front parking sensors will operate when a
forward gear is selected following reverse. Sensor operation is canceled when the
vehicle speed is above 10mph (16kph) but will operate again if the speed drops below 10mph (16kph). This can give instances of sensor warnings when the vehicle stops at a junction and another vehicle or pedestrian passes in front of the vehicle, resulting in the above complaint. This is not a fault with the parking system, however, an alternative system strategy is available so that the system operation is canceled when the vehicle speed is above 10mph (16kph) and will not operate again until the vehicle speed is below 10mph (16kph) and the fascia front parking aid switch is selected (or until a forward gear is selected following reverse gear selection during parking).
Action: On a customer concern basis only regarding the above, refer to the Service Procedure
detailed in this bulletin to renew the parking aid system control module. The new
system operation must be explained to the customer.
NOTE: The new software strategy is contained within the new control modules below and is installed to vehicles
from the closing VIN above.
Parts Required:
Description Part Number Quantity
Parking aid control module YWC500550 1
Labour Time: 0.40 hours
Operation Description Operation No. Time
Parking aid module - renew 86.54.10
Repair/Claim Coding:
Causal Part: YWC500313
ACES Condition
Code:
42
Defect Code:
Service Procedure
NOTE: The new system operation must be explained to the customer.
We have to make LR understand that those of us that want the automatic PDC back should be treated with the same respect that the complaimers got.
I want LR to make the same moduel avaible to us that makes the PDC automatic again.
Why couldn`t they make it an i feature like overspeed warning and lazy entry.
So we could choose automatic PDC ON or OFF
SO WRITE TO LR LIKE ME AT GIVE THEM YOURE PICE OF MIND
Iwant my old automatic PDC back, like I had on my disco 3
PERS
Norway
RR SPORT TDv6 HSE 2007
Buckingham Blue
Ebony Interior
American Straight Grained Walnut
Dynamic Pack HSE
Rear Diff.
20 inch Stormer alloys
Privacy Glass
Premium ICE Pack
Hybrid TV
Personal Telephone Integration system
Tow Pack
Brembo Front Brakes
Bi Xenon Adaptive Head Lights
ADDED on delivery
Grille � perforated with "Titan" finish in buckingham bllue
Twin oval tailpipe finishers
Stormer side vents with "Crome finish"
Mon Nov 13 2006 6:40pm
Josh
Seems a little over complicated to me TDV6 - gone
TDV8 - gone
Mon Nov 13 2006 8:32pm
philmw
My 06 RRS is like this. Not a problem. I quite like it turning off as people stop so damn close when in a queue anyway.
Mon Nov 13 2006 8:36pm
tf9
I just turn it off each time a start the vehicle - works for me... But for the first few weeks the "sheep alert" was a bit disappointing 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Mon Nov 13 2006 9:16pm
I had my 1yr old RRS S/C converted/upgraded to this sequence only last week when I took it in for its 1st service. [ all done under warranty ] - as you say , too many people complained of false BEEPS from the damn system esp from the front. So all that is needed is to book your car in and ask for the new pdc module to be fitted [ refer to my RRS link 1st service to do list ] http://www.rrsport.co.uk/forum/topic3976.html " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC "
Tue Nov 14 2006 11:13am
pers1
I would like to have it automatic not turned off.....I can turn it off my self....
hope for a "old" module that doses that!
PerSRR SPORT TDv6 HSE 2007
Buckingham Blue
Ebony Interior
Dynamic Pack HSE
Rear Diff.
Privacy Glass
Premium ICE Pack
Hybrid TV
Tow Pack
Brembo Front Brakes
ADDED on delivery
Tue Nov 14 2006 10:48pm
The doc
I prefer it without!
But it would be a good idea to have it switchable like you say!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
