![]() | Home > Maintenance & Modifications > Suspension Fault |
caporajm Member Since: 25 Jul 2005 Location: Austin, MN Posts: 55 ![]() ![]() ![]() |
I've realized that it isn't a problem if it goes away when you reboot the car. I always take that computer messages with a grain of salt. i would say you would be wasting your time taking it to a dealer or ever worring about it because it is nothing RRS S/C Special Edition, Vesuvius |
...unless it IS something of course |
1ton Member Since: 28 Oct 2005 Location: USA Posts: 39 ![]() |
I have to take my car in for several other reasons so I might as well mention it. |
Mr Bean Member Since: 30 Sep 2005 Location: Up North Posts: 46 ![]() ![]() ![]() |
Be a little careful,
OMG - I must be missing a warning light........... must get into the dealer as soon as possible and get one retro-fitted.
Guest Member Since: 24 Oct 2005 Location: mansfield Posts: 16 ![]() ![]() |
No need to panic Tim,
just checked my owner's handbook for you Tim and on page 99 it shows the Amber Suspension Warning Indicator. It stays on if the system detects a fault and usually displays a message also on the message centre. Often false warnings though as they usually re-set after re-starting?? tdv6se owner since end of sept 05 |
Thanks GUEST, must have missed that one and it has not yet glowed for me! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Are you Okay Tim? ![]() Don't worry about the light.....it's not that much help if it comes on or not....it has a mind all of it's own! |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
If that was my car I think I'd be asking for a swap by now.... By replacing the compressor 3 times they clearly have not solved it. L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
