![]() | Home > Tips & Tricks > Rear tail light cluster removal |
Be very carful removing the rear cluster - there are 4 clips that can be broken very easily. As I havn't replaced a bulb yet are you sure you need to remove the cluster? I would have thought the access is with the cluster fitted. 2005 Zambezi TDV6 - Gone but not forgotten
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
VA - is it not in your HAYNES manual |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
Watched a guy do this when my Tracker was fitted. I think (?) he removed a couple of screws from the boot-lid side of the cluster, then used a flat piece of plastic to push into the space between the rear of the cluster and the rear wing, presumably to unclip the clips that VA talked about. Cluster is connected to the wiring loom by a large connector. |
NellyP Member Since: 26 Oct 2006 Location: Leicester Posts: 69 ![]() ![]() ![]() |
The answer is on page 277 of your owners handbook! |
Top work NellyP |
![]() ![]() ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
It was cold outside and I didn't want to look! That's my excuse and I'm sticking to it! 2005 Zambezi TDV6 - Gone but not forgotten
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
.....and it was the butlers night off ![]() ![]() |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
A case of RTFM I think!!!! L319 D4 HSE
![]() ![]() ![]() 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
