Home > Technical > Svr wheel bearing
daxmatt
Svr wheel bearing
Are these common to go, not sure if mines on its way out, or its just road noise.
Have 295x40x22, its a new to me car
Post #647643 Thu Apr 10 2025 6:25pm
Farmer Chalk
I’ve had three of them over the past years and the latest has done over 70,000 miles and no problems..
Does the noise change with a change of direction, I.e leaning the car around a bend? How many miles has yours done? Tyre wear? They drive certainly noisier if tyres are towards their end of life…
Post #647650 Fri Apr 11 2025 7:56am
daxmatt
its done 70000, I,m leaning towards the prop or diff, the seal was changed by previous owner, and i've since found out this is a common thing leading to diff failure, ie, seal and pinion bearing not being reset properly.
Could be a warranty claim from dealer. Neutral
Post #647654 Fri Apr 11 2025 4:54pm
