Home > Technical > L320 Active roll control fault.....Help !
Spen17
Bit of a newcomer to Range Rover issues but owning a 2005 4.2sc is proving to be a challenge ! Please bear with me if this all sounds a bit obvious to some.
Currently have a vehicle lean when cornering fault showing on the dash. After scanning with Gap tool there are no suspension faults showing but one Active roll control fault which is C1B14-1C. After checking it would appear to be the lateral accelerometer mounted on the inner sill under the drivers door Part no. RQB 100011. I have checked live value on Gap tool and found this to be 856ft/s when vehicle is stationery. Assuming this to be wrong I replaced it but still get the same result. Can someone please confirm what the values should be at when stationery. Should I be looking elsewhere for this fault ?
Any help would be greatly appreciated. Thanks.
Post #647472 Sat Mar 29 2025 4:02pm
Disco_Mikey
Is the hydraulic pressure reading OK? I ask, as the connectors for the accelerometer and pressure sensor are the same, and can be mixed up
There is also an accelerometer above the front interior light Thumbs Up
Post #647477 Sat Mar 29 2025 6:29pm
Spen17
Thanks for the reply. Fairly sure plugs are not mixed up as the fault has just appeared. However I will check.....assume you are referring to one of the four plugs on the valve block adjacent to the sensor ?
Regarding the pressure check , what live value should I check and what should it read ? Any ideas on the correct values for the accelerometer ?
Appreciate your help
Post #647479 Sat Mar 29 2025 7:08pm
Disco_Mikey
When stationary, the accelerometer should read close to 0
If you still have your original sensor, try swapping it with the internal sensor first, make sure you've replaced the right one
If that makes no difference, you may well have a wiring fault
Post #647481 Sat Mar 29 2025 7:37pm
Spen17
Thanks for the reply. I kind of assumed it should be zero if you are not moving but with these things you can never tell. Thanks for confirming. Still got the original so I can have a look. The wiring is what concerns me. How on earth to track down a breakage between there and I assume its ecu. I have ordered a plug/wiring (plug not serviceable) just in case its that.
Post #647482 Sat Mar 29 2025 8:51pm
