Home > In Car Electronics > L494 Infotainment Software Update
Housty40
Scotland
I’ve used this site for some time now as a great reference point but this is my first post. I have a 2018 L494 Autobiography and love it except for the infotainment system. It needs a software update. So after extensive internet research I’ve found someone on eBay who will be able to help. His eBay name is map-updater-2017. Has anyone used him to either give me an email address or mob no to discuss further his services as eBay don’t like you talking to them outwith eBay. I am in the process of arranging to go see him. Happy if you know him to let him know I’m asking for this and PM me. I am coming down from Scotland to see him. TIA.
Post #647160 Tue Mar 04 2025 9:59pm
jimbg
What version are you on?
Do you not have Over the Updates?
You have Carplay and Android Auto on a 2018. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #647161 Tue Mar 04 2025 10:49pm
Housty40
Scotland
I went through JLR and Here.com as I couldn’t get set up properly. It was them who told me my software was ‘Very outdated’. This they said is the reason why I can’t get SOTA working properly. This guy says he can fix this. I’ll update this post when it’s done.
Post #647162 Tue Mar 04 2025 11:08pm
jimbg
Best of luck!
You haven't said what version you are on, so cant give you any other advice.
Maps only need a valid subscription which I guess you have not bought. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647173 Wed Mar 05 2025 3:06pm
Danilo
Buonasera, ho un problema ad attivare i dati mobili ed il Wifi dell’auto. Andando in concessionaria mi hanno detto che dovrebbero forzare un aggiornamento e che non hanno certezza che questo vada a buon fine, rischiando di bloccare tutto e di dover poi spendere cifre astronomiche. La versione software della mia auto è la s18c. Per caso qualcuno di voi ha riscontrato problemi simili oppure ha trovato qualche soluzione?Grazie in anticipo per le risposte.
Post #647466 Sat Mar 29 2025 2:30pm
jimbg
Do you have a valid Pro Services subscription?
https://www.landrover.co.uk/ownership/inco...-faqs.html 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647469 Sat Mar 29 2025 2:42pm
Danilo
Sul mio incontrol c’è scritto che il pro service scade nel 2035
Post #647470 Sat Mar 29 2025 3:12pm
jimbg
Are you using a data only SIM, such as used in a tablet?
Are you sure it is ready to use and does not need any setup?
Obviously different to UK but SIM are you trying to use?
Can you ask dealer to try a known working SIM in your car? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647473 Sat Mar 29 2025 4:37pm
Danilo
Sì sto usando una sim solo dati. Ho provato a fare anche il soft reset. Ho fatto staccare la batteria dalla concessionaria stessa ma niente. Mi hanno solo detto che è necessario fare un aggiornamento forzato con il rischio che si possa bloccare tutto, però onestamente non sono propenso a correre questo rischio a mie spese, perché mi sembra un po’ ridicolo. Per questo ho chiesto qui se qualcuno di buon cuore avesse qualche soluzione
Post #647474 Sat Mar 29 2025 4:55pm
jimbg
In that case it maybe the SIM card reader is faulty, there were prone to fail.
Version 18C was fine for it to work, I started on Version 17 and used the facility OK.
I am now on version 22 which is the final one.
I would insist on getting the dealer to get it working on version 18 as that is a supported version. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647475 Sat Mar 29 2025 5:25pm
Danilo
Infatti lunedì la porto da un elettrauto locale per fare una diagnosi per capire cos’è che non va. Mercoledì poi vado in concessionaria per far fare la diagnosi a loro per capire se è qualcosa di poco grave. In ogni caso grazie jimbg per il tuo tempo
Post #647476 Sat Mar 29 2025 6:23pm
jimbg
Buona fortuna 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647478 Sat Mar 29 2025 6:32pm
