Home > Maintenance & Modifications > D4 SAT NAV upgrade to 2005-2008 RRS
The disco boys have been upgrading their D3's to fit the D4 SAT NAV unit.
You can also do this to the Early RRS too.
You fit a new display unit, which has all the navigation built in, (it contains a hard disc).
It will also display a reverse camera image (without GVIF) providing you have a GAP IID.
It's a better touch screen with new graphics and newer maps.
Follow guide here:
https://www.disco3.co.uk/forum/discovery-4...82701.html
RRS specific:
Remove the top section of the plastic as shown on the D3 site.
Also chamfer the raised part to allow room for the fibre optic connector and GPS connector.
Get a heat gun on the heating duct at the top, and then quickly screw the display in place, so the duct sets in the correct place.
Glue your old screen surround, to the new display.
Parts required.
Suitable denso display (see other thread) (Bosch is not suitable)
Connector shell for new display
Camera adaptor cable (if you are fitting a camera)
GPS extension lead. 3m
Only snag is the display is at maximum brightness. You can turn it off at night though.
Post #594672 Mon Feb 10 2020 10:05pm
savi18
New Zealand
Thanks for that, being in NZ this would be very difficult obtaining bits, and getting NZ maps as well, plus reading through the post it only works on the Hi Line systems and not the lower base model which i have got, love to take it on if i was in the UK.
Post #647153 Tue Mar 04 2025 11:47am
Billy82
I have fitted this to a 2006 rrs but can get the reverse camera to work i enabled it with sdd but i do t know what else needs doing. I can see image on hidden page.
Post #647200 Fri Mar 07 2025 11:13pm
It’s not enough to enable the camera.
The gap iid does some magic stuff to get it working as per a year 2010 car.
Try saying it’s a 2010 car
And 360 not fitted
Post #647203 Sat Mar 08 2025 7:30am
Billy82
Would changing car year do anything to upset the car. Do you have sdd to see whats changed
Post #647205 Sat Mar 08 2025 7:59am
Billy82
Did you fit a rear camera
Post #647206 Sat Mar 08 2025 8:00am
I don’t have an sdd
Yeah I fitted a camera. Used gap iid to enable. Selected camera MY10
It’s a cheap aftermarket camera
Post #647209 Sat Mar 08 2025 12:11pm
