Home > Maintenance & Modifications > Model L461 how to fit side steps?
Adamba
Hi All,
Has anyone fitted side steps to their 2023 onwards RR Sport? Help please!
I purchased an aftermarket set that are "simple to fit" but have now found that, after speaking to the supplier, I need to cut away some of the plastic coverings on the underside of the car to make the brackets fit, and better still, the supplier doesn't have fitting instructions and can't tell me exactly where the threaded hole are to accept the bolts. I think I've located the threaded holes for the rear mounting, but have no idea where the front holes are. On the basis I've only covered 1400 miles, I'm a little reluctant to start unscrewing covers without knowing what is behind them.
Has anyone done this already and coudl you send me some advice, photos etc please.
Thanks in advance all.....hopeful I'm not the only one to being trying to do this!
Post #641419 Tue Apr 23 2024 6:23pm
scrumps
If they are like the deployables on my 24MY AB, you’ll need to buy the auxiliary jacking point kit too.
Fitting instructions for the OEM ones are here:-
https://topix.landrover.jlrext.com/topix/c...86640!1!51
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #641447 Wed Apr 24 2024 11:59am
Laurie100uk
Hi, did you get these fitted in the end? I've also just bought a kit on ebay which was "bolt straight on" and now realise its far from it.
Post #641964 Wed May 15 2024 9:19am
drbaud
United States
Hi.
I just installed Sidesteps on my 2025 RRS and I had the same concerns you are expressing. The dealer gave me this link ( https://accessories-instructions.landrover.com ) which helped me with the shape of and the location to cut the shield. The actual cutting using an Oscillating Multi-Tool was very easy to do.
Hope this helps
Al
Post #647198 Fri Mar 07 2025 8:41pm
