Home > General (L494) > Exhaust leak?
Karlp606
Exhaust leak?
Hey guys - over the last few weeks I’ve noticed a small ticky type noise on driving coming from someone low in the cabin, thought it to be the cold weather and short journeys so thought nothing of it- just drove to Manchester airport 2 hours straight driving was lovely and smooth , but as I parked up my wife opened the passenger door and all I could hear was a louder tappy / puff puff type noise , so parked up with the engine running and lifted the bonnet and I could smell exhaust fumes - seems to be the passenger side of the engine - bad leaky gasket? I had both engine manifolds done about a year ago and I’m not getting the loss of power restricted performance error so I’m guessing more exhaust based?
Any ideas?
Post #646781 Fri Feb 07 2025 7:00pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Sounds like an injector copper washer has failed, try lifting some of the sound deadening on the nearside bank and see if you can see any residue or see any blow by with the engine running.
Post #646783 Fri Feb 07 2025 8:11pm
Karlp606
Thanks just seen can be a common problem on the injectors - Cars going into drop n go car park tomorrow for 2 and bit weeks so will give it a check over when I get home. Presume car will be okay to drive home again - about a 2 hour drive.
Post #646784 Fri Feb 07 2025 9:09pm
2 RRS
I'd say so, I drove back from the French Alps, approx 1k without any issue, just a bit of fumes in stationery traffic. Easy enough repair, replace the copper washer and o rings as well as the clamp plate and bolts to be sure of a 100% fix. Not expensive for gen parts.
Post #646785 Fri Feb 07 2025 9:14pm
Karlp606
Thanks man will have a look - car is in airport car park for 2 weeks now so will check it when get back - either that or a loose exhaust clamp? Definitely a puft puft type noise that gets faster with accelerator around the passenger side of the engine - cabin had a strong smell this morning when drove from hotel to airport car park
Post #646786 Sat Feb 08 2025 12:11pm
2 RRS
The crossover pipes are a bit prone to cracking also, but if the sounds the same when the engine is warm I'd say a copper washer, as usually if the crossover is cracked they tend to seal a bit better when warmed up.
Hope it's the injector, it's easier and cheaper!
Post #646789 Sat Feb 08 2025 1:55pm
Karlp606
Yeh it seemed to louden as engine got warmer.
Would anything show on a diagnostics as I’ve got my LR II in the boot so could plug it in when I get back check fuel pressure?
Post #646795 Sat Feb 08 2025 4:46pm
2 RRS
Mine never showed any codes whatsoever, if you just lift the foam insulation on the nearside bank, you'll see fumes and smell it big time when it's running.
Go and enjoy the holiday and worry about it when you get back!!
Post #646800 Sat Feb 08 2025 5:33pm
