Home > General (L461) > hybrid problem
dsw_no1
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
hybrid problem
Hi, I have a 2024 RR Sport 460e, and it seems to have problems running as purely EV. I get an error message on the dashboard display saying " EV temporarily not available" and it just runs on petrol engine alone. Most times when I stop and turn off the engine it seems to reset itself and run ok as a hybrid again - but not every time.
The supplying dealer (Stratton Tonbridge) want to charge me £225 for a diagnosis report, which I'm not willing to pay for what must surely be a warranty issue? Car is 8 months old with less than 4k miles.
Has anyone else experienced this fault please, and if so what was involved?
Thanks for any help, Chris
Post #646726 Thu Feb 06 2025 1:27pm
jimbg
Could be the HV heater.
Turn the heating off and see if it starts in EV mode, then try it with a high AC temperature and see if if it starts in EV mode.
If it does start with a high temperature on the AC, then it's because it is using the engine to generate heat as the HV heater has maybe failed.
The other reason the engine starts is because you have a high 12 volt load, such as heated screens on, heated steering wheel, etc. Then that is Okay. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #646729 Thu Feb 06 2025 2:58pm
dsw_no1
Thanks very much, I should have thought about that - especially re the high 12v load. Really appreciate your quick answer too, shame my dealer wasn't able (or interested) to help!
Post #646730 Thu Feb 06 2025 3:30pm
jimbg
Ha! Ha!
Been through all this with my P400e. Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #646732 Thu Feb 06 2025 4:15pm
RR Ally
I have the P510e and the same thing occurs to me when I first start the car in the morning. I drive for about 5 miles and then I can select EV only, before then I get the same message as you.
My local dealer told me that this was because the petrol engine had to get warm first, upto normal temperature, and also the start battery had to be at a certain voltage.
I would just like to start off in the garage at home in EV mode. and select hybrid and let it do its own thing. 2022 P510e RRS AB Frenze Red
2021 BMW i3
Post #646736 Thu Feb 06 2025 4:38pm
jimbg
It's always possible to drive in pure EV mode if you do not have a heavy 12 volt load.
My P400e is kept on the drive and always works in pure EV mode unless I switch on the heated screens, etc.
Next time you drive off make sure you are in EV mode and no heated screens on. If the engine starts you have a fault, almost certainly the HV heater.
It's the only fault I have had and until someone pointed out the test I thought it was normal. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #646737 Thu Feb 06 2025 4:51pm
dsw_no1
I really appreciate the advice, thanks. What a shame my dealer wanted to charge me £225 for it though!
Post #646738 Thu Feb 06 2025 5:23pm
bcp
Our P460e is running as an EV for the majority of the time despite low temps. Our P300e DS however had the same symptoms as above and needed both a new HV heater and various software refreshes.
Post #646758 Fri Feb 07 2025 10:53am
Tizzy
I had two HV heaters replaced on my P400e - it’s a well known problem as already said and why I’d never recommend anyone to get a P400e.
Post #646759 Fri Feb 07 2025 11:23am
jimbg
Unfortunately HV heater failure is common across all makes, not just JLR. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #646762 Fri Feb 07 2025 12:55pm
Standard dealership behaviour, sadly. They've had your money so they're not interested in helping you now. Censored 2012 SDV6 - it's missing a couple of cylinders
Post #646766 Fri Feb 07 2025 1:32pm
Dan_NL
Netherlands
The failure has one thing in common : Webasto, the producer of the heaters.
What strikes me is that ALL cars that have the LG-Chem batteries ( I-Pace, Taycan, Audi ),
also have the same heater problems, with the same heater.
But why the P400e ( I used to own a P400e RR, and joined the forum thinking of buying a RRS),
has the same problems : could it be the same partnumber heater element ?
What I read in the last few posts definitely puts me off getting a P400e / P440e/ P460e /
P510e of Land Rover or Jaguar, as even the DS has this problem.
Before production of P440e started they knew the heater was an an issue.
It feels like an 'encore' of the misery with the TdV6, that also festered on for a decade almost.
https://www.taycanforum.com/forum/threads/...res.20507/
Post #647039 Sat Feb 22 2025 7:23pm
Claud
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
If you have Land Rover Assistance within warranty you can call them and they will send out someone (or the AA) and do a diagnostic for free. I have used them several times.
LRA diagnosed a faulty battery cooling system pump on my wifes P400E, we booked it in and it was fixed under warranty at no cost. RRS Autobiography P460E
Post #647529 Wed Apr 02 2025 5:00pm
jimbg
I asked LRA to come out and they refused as the car could be driven on the engine and therefore was not broken down. Big Cry 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #647530 Wed Apr 02 2025 5:06pm
RR Ally
JLR have just diagnosed my EV problem, not selecting EV mode until its been driven for about 15 minutes as the HV heater.
However the local Land Rover dealer does not have the "special tool" needed to replace it, so I have to drive the car about 50 miles to the next dealer for the work to be done.
The only good news is that the heaters are in stock. 2022 P510e RRS AB Frenze Red
2021 BMW i3
Post #647557 Fri Apr 04 2025 8:27am
