![]() | Home > Wheels & Tyres > L494 wheels with 255/55/20 tyres on L320 - now fitted |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
No DSC issues on ours - just gone from 275/45/20 to 265/60/18 on compomotive pd1881. Car handles better, goes better, speedo reads more accurately and looks better in my opinion. Its also now cleaner so I may even get a picture this weekend. If within the reasonable tolerance of size that the system is built with there is zero reason for a tyre size change to cause eroneous TC action. however if a sensor is malfunctioning not failed then a change in operating range could cause issues. what I mean by that is if a sensor is on the way out then it may not perform to spec at the extremes of its range. If you look at the possible sizes in the CCF there are a great many and the system can cope with them fine but like most things sensors are starting to age on these cars so their performance will not be "box fresh" anymore 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
I found 4 instances of people having issues with larger tyres than standard on the RRS; only one of these used the 255 55 20 size tyre as mentioned in this Forum. The other cases were unspecified “larger tyres”. These problems were specifically DSC related when cornering.
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
If it helps, my 2010 came with 255/50 x 20s, changed to 275/45 x 21s, no issues at all, even before I used IID to change wheel and tyre dimensions/sizes. 2010 3.6 TDV8 HSE (Gone)
Privanthe Member Since: 28 Dec 2019 Location: Scotland Posts: 24 ![]() |
Any issues with rubbing on these? |
No, all fine, even in access mode. Kev
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 213 ![]() ![]() ![]() |
Kev
Yes, he always has plenty available. I think the shipping charge is about £75 for a pallet. I'll PM his contact details over to you. Kev
Kev,can you please send me his details as im after a set of 21"s the nine spoke,i was going to put a new set of tyres on my 22"s but I want to change the wheels so might get a set from him if he has what I want/need.
Will do |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Hi guys from downunder.
Benallen Member Since: 02 Feb 2025 Location: Prestatyn Posts: 2 ![]() ![]() ![]() |
[quote="knwatkins"]I saw some wheels advertised locally at a good price. All wheels immaculate, original factory condition with 7mm of tread on all, Michelin Latitude Sport tyres. One thing that did concern me was the tyre size at 255/55/20 which compared with the L320 at 275/40/20 is a significant increase in sidewall depth.
