Home > General > Heated wing mirror not clearing
JonnyCJ
Now we’ve actually got some cold weather, I’ve noticed my offside wing mirror glass isn’t clearing. Looks like it’s on the same fuse as the near side.
Is this likely to be a dicky mirror glass rather than anything else ?
Could be a previous owner has just fitted a non heated glass, so will investigate at the weekend when I look at the windscreen issue as well.
Is glass removal just a good old pry off with trim removal tools ?
Thanks in advance
Jonny
Post #646143 Tue Jan 07 2025 10:46pm
Angle the lens so you can get your fingers behind it and give it a firm pull, don't yank it straight out too far as the heated element wires are there. Re-fitting it just requires a firm push around the centre of the lens.
Post #646144 Tue Jan 07 2025 11:04pm
JonnyCJ
Thanks Col - you and AndyK really are the AI Fairies of the forum !
Jonny
Post #646152 Wed Jan 08 2025 9:33am
JonnyCJ
Popped it off and checked the continuity. Zero beeping from my multimeter, so a new one ordered courtesy of eBay.
£16 delivered, which is nice.
Post #646205 Fri Jan 10 2025 10:49am
JonnyCJ
New mirror put on and working well. Happy days.
Time saved thanks to the forum - probably 15-20 mins googling, but the advice was spot on first time.
£ saved - probably £50 or so over JLR bits
Post #646454 Thu Jan 23 2025 4:49pm
