![]() | Home > General (L494) > Restricted Perfomance issue... |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 73 ![]() ![]() |
The Indy should have been able to read the DPF percentage.
A bit of an update on my last post.
If you’re showing a mass air correlation error you have an air leak between the airbox and inlet manifold. Could be a loose clip, cracked inlet manifold, split pipe, etc. Check them all. Once that is sorted out your DPF will reward you with fewer regens and less shooting up. Right now you’re making the DPF work more due to the intake having a leak. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Many thanks for that info'. I'll get my Autel back on it after I've done the oil change and see what's what. Cheers. A Cheshire expat in France.
Oil & filter change done, all reminders reset and only 1 fault code, that's for the stop/start battery, but I've disconnected the earth so it doesn't work.
