Home > General > Battery voltage question |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4995 |
I had a Jag that had the pitted contacts on the starter relay. So I would suspect that was your issue. |
Fri Dec 13 2024 1:22pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 215 |
Thanks Andy
Fri Dec 13 2024 1:24pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1845 |
Measure it across the terminals
Fri Dec 13 2024 1:33pm |
Thanks Jim
Fri Dec 13 2024 1:37pm |
Right, multimeter sorted.
Fri Dec 13 2024 3:41pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Battery needs charging with a decent smart charger. Although I reckon it's looking a bit tired. A drop from 12.2V (not great) to 11.3V (rubbish) suggests either it needs a decent smart charge or it's . Charge it and see what happens. Edit: I see stuff changed. Typical. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Dec 15 2024 12:12am |
Thanks for your reply RRSTDV8, yes, both the battery and alternator were replaced with LR genuine items just over 4 years ago/27000 miles ago.
Sun Dec 15 2024 9:21am |
Well, just popped out in the rrs, pressed start and then 'click', the second press it started fine.
Sun Dec 15 2024 2:02pm |
