Home > Technical > L320 2012 Tailgate open warning - can't lock vehicle |
drexal Member Since: 17 Dec 2019 Location: london Posts: 116 |
Hi all,
Sat Nov 30 2024 5:51pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4977 |
There are several options for the tailgate in the CCF files, but none appear to mention turning off any warnings, only a thought but could you loosen the hinges slightly and flex the tailgate enough to latch correctly, only thing is if that did work whether it would release again, if not would probably be in bigger mess than ever, could possibly remove the tailgate lower trim panel first which might allow you to get to the latch from inside the car if it did, as I say only a thought though.
Sat Nov 30 2024 9:07pm |
Hey Col,
Sun Dec 01 2024 1:05pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 368 |
Just thinking outside the box. To my mind the hinges are very strong and it would take a lot to bend them. Could it be that the actual plate area the hinges mount to are bent ? Bear in mind the hinges bolt into sheet metal, albeit probably with a reinforcing plate behind the panel that the bolt threads go into.
Sun Dec 01 2024 6:35pm |
Hi, Insurance here is not to bad, works out about the equivalent of £800.00 sterling fully comp. but pay a bit extra as have a agreed value if car is totalled. One of the most stupid thing here is you don't even have to have insurance not even third party. Just done the registration (UK Ved) for the year cost $140.00 (£70). I probably only do around 4/5K a year these days so can't really see any point in replacing it, does everything I want, long bought and paid for and it's never let me down, not even a flat battery, apart from annual services the only thing the engine has had is alt/supercharger belts and sparkplugs at 7 year service, only suspension bushes it has had is front lower arms and bolts and the was due to a leaking hydro bush initially, obviously had discs and pads etc. and a few other bit's but not much. Cheers Col |
Sun Dec 01 2024 10:07pm |
