Home > In Car Electronics > Rev counter needle "NOT LIGHTING UP"
garfield
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Firenze Red
Good evening Members,
Range rover sport 3.0
Autobiography.
I've just driven home in the dark and noticed my rev counter needle is not lit up,reading around it looks like instrument binnacle needs removing to get it repaired (BEYOND ME),the repair that is! Does anyone know how to remove the gauges?The earlier models looked easy but I am scared if the steering wheel needs to be removed? Any advice would be appreciated.
Thanks Gary.
Post #645437 Sun Nov 24 2024 8:00pm
If you extend the steering wheel towards you, and lower to the lowest position it is possible to wriggle the instrument cluster out, but it is far easier if you remove the steering wheel first and less chance of scratching the cluster clear plastic and leather trim etc. also easier to see the screws etc. removing the steering wheel is not overly difficult if you have the airbag release tool or it can be done with a bent metal coat hanger.
Post #645461 Tue Nov 26 2024 4:34am
garfield
Hi Col,Thanks for reply,Its just all the trim panels that have to come off first how and in what order.I know the earlier ones were relatively easy,but this does look well paneled in and it has paddle shifters etc.Do you know why the needle fails to light up?
Gary.
Post #645465 Tue Nov 26 2024 10:35am
If I remember right, but I could be wrong the illumination in the instrument panel are SMD Led's and one is positioned to project the light up the transparent rev counter/speedo needles, so perhaps one of the led's has failed, but as I said I could be getting confused with something else as it was while ago I took one to bits.
Post #645488 Tue Nov 26 2024 8:39pm
Billy82
Is this the earlier range rover sport. As they are as described. I have changed my leds as I didn't like the green
Post #646003 Mon Dec 30 2024 9:48pm
