Home > General (L461) > MY 24 Bongs
Chips
MY 24 Bongs
When you select 'Low' on the driver assistance I still get bongs on every speed limit change, is this right on MY24, it is driving me nuts and completely ruins the point of warnings bongs, you get so many that all of them get ignored. Not so bad out in the country but when in towns the thing literaly will not shut up ! Every round about usually leads to four bongs and even driving through a retail park it's non stop bongs Evil or Very Mad
In the settings it says no speed limit warning on low setting so is this a fault with my car or are all MY24 the same ? MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #645413 Sat Nov 23 2024 7:53pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Think it is a legal requirement on MY24 cars. Mine is the same. Just need to stay under speed limit! 😉
Post #645414 Sat Nov 23 2024 10:35pm
Chips
But it bongs every time the speed limit changes regardless of whether under or over the limit and usually an extra one a few hundred feet before the limit changes which translates into about four bongs per roundabout ! In addition it seems to bong for no reason what so ever half the time and so it just becomes very annoying white noise. MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #645420 Sun Nov 24 2024 11:42am
scrumps
Hi Chips,
Have you had a look at your settings for “custom” on the touchscreen.
I’ve just checked my 24MY and you can select “Speed limit warning” to “Off”.
It’s simply a point of two presses of the steering wheel button on each start-up to engage “custom”.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #645424 Sun Nov 24 2024 1:16pm
Workpermit
When I switch mine to Low, I don't get any bongs. 2024 RRS L461 P460e AB
Post #645431 Sun Nov 24 2024 5:10pm
Chips
I think something is wrong with mine then . I will try setting custom to no warnings and see if that works instead of setting to Low MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #645438 Sun Nov 24 2024 7:01pm
Lofc07182
I always activate custom mode by using the shortcut button on wheel, so don’t get any audible warnings.
Post #645643 Fri Dec 06 2024 11:37am
discobob
MY 24 Bongs
Hi Chips,
I had this as well after picking up my RRS. Drove me crazy but have now found how to turn this off. It's not in the custom settings (where you would expect) but there is another setting deeper within the main software settings :
Go to Vehicle -> Driver Assistance -> Cruise and Limiter -> New speed limit notification
Hope this helps Thumbs Up
Bob
Post #645894 Mon Dec 23 2024 12:50pm
Chips
Thanks Bob,
Sorted Thumbs Up MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #645902 Tue Dec 24 2024 7:14pm
Salmon&permit
This sorts out speed bongs….but has anyone worked out whether it is possibly to disable seat belt bongs as with previous LR cars? The 9 or 10 times in/out trick doesn’t seem to work any more and when I am fishing and driving around in waders and getting in and out and opening gates, it’s a pain in the a@@@! SDV6, Supercharged V8, SDV6 Hybrid, PHEV
Post #646168 Wed Jan 08 2025 6:47pm
sterling01
Scotland
I bought these. Put something heavy on the seat and it thinks its a person. Plug this in and it thinks the seatbelt is in place.
https://www.ebay.co.uk/itm/156395737546 Current - 2020 Range Rover Sport P400e
Gone - 2014 Range Rover Sport HSE SDV6
Gone - 2017 Audi A8 Sport
Gone - 2007 Range Rover Sport HSE TDV8 - Great car.
Post #646537 Mon Jan 27 2025 9:11am
