![]() | Home > Faults & Fixes > Vehicle lean warning |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 781 ![]() ![]() ![]() |
When I had that it was a yaw sensor (I thunk) that needed calibrating. |
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
Hi there - might be worth starting with checking the connections to the ACE valve block - you’ll find this underneath the car, below the drivers seat (assuming right hand drive) … you can do this with a bit of patience, and without having to dismantle stuff ….
