![]() | Home > Faults & Fixes > P049C-00 (27) Exhaust gas recirculation - B - Excessive flow |
Milstad Member Since: 31 Mar 2013 Location: Peterborough Posts: 5 ![]() ![]() |
Update on EGR issue. I found Halfords Autofix quite helpful and tested the wiring on the 5 pin plugs - wiring from ECU to EGR plug is all good. Left EGR valve still showing 0% Actual, vs varying Commanded values.
Just an update for anyone else suffering the same fault code - I fitted a new throttle body and MAP sensor and all is well. |
cameronholder23 Member Since: 31 Oct 2024 Location: Colorado springs Posts: 1 ![]() ![]() |
WHEN YOU INSTALLED NEW MAP SENSOR AND THROTTLE BODY, WAS THE VALVE POSITION ACTUALLY READING OR WAS IT STILL AT 0%? |
