Home > Technical > White sheathed cable in boot - What is it
Meshan
Hi, I recently bought a 2008 L320 RRS.
The DVD plyer isn't working so I have removed it to see if I can fix it.
While undert the boot trim, I saw a large cable, with a white corregated plastic sheath. Inside the cable is a wire with a black top. The wire isn't attached to anything. The wire moves back and forth like a lawnmower throttle or similar.
When you move the wire back and forthe, there is a sound close by like a meatal gear is moving.
My question is, what is the wire? Is it meant to be attached to something?
I wish I took a photo.
Post #644784 Sat Oct 19 2024 7:28am
Fuel filler flap release cable, should lock the flap when you lock the car, one end attached to a solenoid other end attached to fuel flap catch, I believe these catches do have a habit of breaking.
Post #644785 Sat Oct 19 2024 8:07am
Meshan
Ah, so it should be attached to something?
Censored , I need to take the trim out again.
Post #644786 Sat Oct 19 2024 8:15am
Meshan
That was a reallt tame word.
Post #644787 Sat Oct 19 2024 8:16am
Meshan
And thank you. Was going nuts trying to google it.
Post #644788 Sat Oct 19 2024 8:25am
https://drive.google.com/file/d/1Svib_6bng...sp=sharing
Post #644789 Sat Oct 19 2024 8:31am
Meshan
Thanks again
Post #644790 Sat Oct 19 2024 11:02am
Meshan
Update
I bought a new actuator as I wasnted to rob the cable. Aftermarket ones are on ebay for about £40.
I now have a spare.
The old just pushes back into the gromet with a plastic trim tool, with a fork.
A little oomp, and it popped on. Still have the spare in case the plastic is weakened, but it took some pushing to get it back on.
Thanks again.
Post #644868 Wed Oct 23 2024 1:10pm
