Home > Technical > Fault code C1A00-54 (AF) in Active Roll Control |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
It would be worth checking the connectors to the module. If they were disconnected during the work then they might be loose - pulling on the harness to pull the connector off the module can loosen a wire. I had this once with the air suspension module. A reach up under the dash and push on all of the wires cured the transient error message. The dynamic module lives on the A-pillar on the driver's side and can be accessed from the driver's footwell once the lower panel is removed. 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 01 2024 10:05am |
Also, see this thread on the sister site: https://www.disco3.co.uk/forum/solved-susp...73332.html 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 01 2024 10:07am |
